jmartinarch Posted March 16, 2017 Share Posted March 16, 2017 A strange thing has happened on the last couple of projects. In one case a few dimensions (text only) changed color from black to blue. In the other case both dim. lines and text changed. In some of the instances they appear as black in design layers but blue in sheet layer viewport, in some cases they appear as black but print blue. What could be going wrong? I've checked text styles, and the individual dimension strings to see if the attribute was changed but all are set 'by class' and the class is black. Quote Link to comment
Andrew Davies Posted March 23, 2017 Share Posted March 23, 2017 Are they on the dimension class? Have you checked that class too? Quote Link to comment
