AlanW
Swimming pool by Marionette
Hi attached are a few different ways to do pools. The last 2 are freeform in plan. One has a shape and the other control geometry. With the control geometry its on a separate class, if its on it shows upside down. will need to fix. But gives you ideas how to create these. If you lose the textures just reset them. Also adjusted the oval node similar to the Rectangle so you can select the centre easily. @Josh NZ
Pool_003.vwx
Edited by Alan Woodwell
