BK Posted November 20, 2003 Share Posted November 20, 2003 Does anyone know how to get rid of the colored lines that attach themselves to the corresponding classes? When I import a DWG file, those lines that reference the class structure (like a grid) are so abundant, I can't see the drawing. BK Quote Link to comment
zero Posted November 20, 2003 Share Posted November 20, 2003 Well Barry, I don't know if I've understood you, but.... Are you sure they are not AutoCAD Point objects, grossly out of scale? Try doing a custom selection for Type is 2d locus, then delete them all (I think I've done this before ). Quote Link to comment
Guest Posted November 20, 2003 Share Posted November 20, 2003 Do you have black lines horizontally and vertically all over the drawing? If you do, turn off (remove the check mark) Snap to Loci in VW preferences. If you see lines all over the place that are colored red, blue, yellow, pink, etc, they may be grid lines the ACad user placed. If that's the class, try to see what class they are in and turn that class to be invisible. You should be able to click on them and see what class they belong to by looking at "Class" in the OIP. If you can't select them, check to make sure Class Options under the Organize menu is set to Show Snap Modify Others. Quote Link to comment
TiTaNiuM sAMuRai Posted November 20, 2003 Share Posted November 20, 2003 Or do a custom selection, select all 2D locus objects, and delete them. Quote Link to comment
BK Posted November 21, 2003 Author Share Posted November 21, 2003 Thanks Katie! That did the trick. Quote Link to comment
