har
Dynamic Image Link
Hi all,
I'm revisiting our Title Block at the moment. While I'm at it, I'd like to add a feature that we (similarly) used to have in AutoCAD:
The Title Block comes with a field for the client logo - That naturally keeps changing.
Right now, we're just dragging in JPEGs and manually scaling them - I'm not a big fan of that.
The first option that comes to mind is the one I'm using for language options:
Have every option in a different class and turn on/off the visibility accordingly.
However, that just bloats up the template file and we have to adapt the template everytime we have a new client.
I'd like to have a little Marionette Node that does the following for me:
- Look Up a specific network folder
- List all contained image files as options to chose from
- Create a linked image based on the selection
- Find the maximum in width/height and scale to fit the "frame"
Is that doable?
Any hints to VS functions I should check out for this?
Thanks to all in advance!
Hi, Try this one, its a simple one. You will obviously have to create your own client logos etc but the principal is the same. Will look at a few other ways to do this like a dropdown menu.
HTH
Title block_001.vwx
Edited by Alan Woodwell
Hi Alan,
thanks for the quick example.
Unfortunately, it's not a ideal option as I'm still having to edit my template anytime we have a new client.
In the meantime I've found out how to create symbols from images in a folder by studying this example:
http://developer.vectorworks.net/index.php/Python_Sample_Import_Images_as_Symbols
So far, so good. Now I only need to have a method for selecting the correct symbol.
Having the loop additionally create a list of all options is one line added to the code.
However, populating a Pop-Up GPIO object with this list won't work as far as my research goes... I hope someone disagrees with me here ;)
Hi Alan,
thanks for the support.
I've gone down a little different route with this now:
Instead of searching through a folder, there just needs to be a "ClientLogo.jpg" in the same directory as the document. Still better than what we used to do.
Best
Hannes
Hi Hannes
A referenced Image, with a relative path, nearly could do that. But with a new image, the scale would be wrong. So you're right, searching an automatism with marionette.
Maybe the attached Node/Example can help yo to realize that. I do not know exactly, how you want to Link your Drawing to the logo. So maybe this needs to modified. The Attached Node supports the following options:
1. Path Name Absolute
2. Path Name automatically to the drawing path and automatically takes jpg with the same name like the drawing.
The Node scales the image to a fixed x-value and scale from the middle. Maybe there needs to be modification to get exactly what you want to have.
Dom
importImage.vwx
importImage.mp4
Hi Dom,
thanks for you support.
I maybe wasn't clear on my last post: My script is already done! It looks quite similar to your approach :) Anyway, as said I'm only linking to one specific file path in the document's directory.
