brettSF Posted August 16, 2016 Share Posted August 16, 2016 I've attached a quick sketch of a concept I'm trying to implement. I've got a few different spaces with different ceiling heights, and I cannot figure out a good way to execute... Assume that I'm only using three materials -- framing, finish surface, and concrete floors. [img:left]http://imgur.com/h1U8OT2[/img] Condition 1: an 8' tall niche (wall return beyond shown in light gray). I have tried two methods here: 1a: A full 12' high wall with an 8' tall Door Opening in it. Unfortunately this creates a condition where the finish material is on both the interior and exterior faces of the wall all the way up to the lid. Obviously above 8' I do not need finish material on the inside (cavity side). 1b: Draw 8' walls in the shape of the niche, and then draw a second continuous wall overhead (from 8' up to 12'). I cannot get the Slab command to play nice, so the "side" of the ceiling graphically overlaps the outside face of the wall. Condition 2: Different ceiling heights on either side of the wall. Framing should continue up to 9', but finish material height varies (8' and 9'). Condition 3: Wall and ceiling all terminate at 9'. No particular issue here, but it's a twist on the issue found at Condition 2, and may help or hurt a solution... If anyone is super proficient and would rather model the solution I'd love to poke around in a "correct" VWX file! Quote Link to comment
rDesign Posted August 17, 2016 Share Posted August 17, 2016 You can control the height of the finish material on the cavity side by creating an 8'-0" Level in that Story and then setting the Component Top for that cavity-side Wall Component to be bound to that 8'-0" Level. For the other conditions you would create another new 9'-0" Level. You may end up with three or four different Wall Styles for all the different top bounding conditions. Each Wall Component in a Wall Style can have a different Top (and Bottom) Bounding condition. If you don't have much experience with Levels this lengthy thread is a good place to start. It's easy to get confused. Quote Link to comment
brettSF Posted August 17, 2016 Author Share Posted August 17, 2016 Thanks Tim! I'll start experimenting with Levels -- hopefully it's the solution I'm looking for! Quote Link to comment
rDesign Posted August 18, 2016 Share Posted August 18, 2016 Digging through my old Vectorworks references, I came across this PDF describing U.K. BIM Templates in Vectorworks 2015 — it's generally pretty helpful regarding setting up Story Levels and "bounded" wall styles. BIM-Templates-in-Vectorworks-2015-SI.pdf Quote Link to comment
