Josh NZ Posted August 15, 2016 Share Posted August 15, 2016 I have several polygons and rectangles drawn, the attributes are set to show a grey gradient. If I move a node the gradient position moves. Also If I use the eyedropper and take the gradient attributes from one polygon to the adjacent polygon the two look different, if I then click on the Fill Gradient Settings and exit without making a change the polygon will then look correct. Is there a way to fix these settings? Quote Link to comment
