Josh NZ Posted July 21, 2016 Share Posted July 21, 2016 Can anyone please explain what is causing the following. I have 20 Detail Callout Markers, they all show as a circle with two lines of text which is close to what Im after. I want to show the symbol that has the horizontal line over the circle that separates each line of text. I click on the Graphic Option button and the correct symbol actually shows, so I click Cancel and now the correct one is showing. The next issue is that I need to get all of them to show correctly even thou each has the right symbol associated. I select all symbols, pick the correct symbol (again) and click OK. Only one changes. Try again and select a different symbol, still only one changes. Quote Link to comment
