krw Posted June 30, 2003 Share Posted June 30, 2003 After upgrading to mac system 10, I am having a problems getting worksheets to print with the correct font. They default to geneva or something. They look correct on screen but print incorrectly. The font I am trying to use, frutiger, is being used in text blocks and notes on the same sheet and these print fine. Any suggestions? VWA 10.1.2 Mac os 10.2.6 Quote Link to comment
krw Posted June 30, 2003 Author Share Posted June 30, 2003 I just found out it is a known bug between vw and os 10. Quote Link to comment
Guest Posted June 30, 2003 Share Posted June 30, 2003 The bug is with the OS and the type of font you are using. WIthout the workaround built into VW, the text in worksheets would print out bunched up when using Adobe Type fonts. Instead, the defualt OS font is used. THis is a problem between Apple and Adobe. I am not sure if this problem is included iwth the other font fixes included in the latest OS fix. I am still investigating that. If so, we can consider taking the workaround out of VW, however we still have a large handful of people using OS 10.1. Quote Link to comment
