AlanW Posted July 2, 2016 Share Posted July 2, 2016 (edited) Jim, The attached file EAP object moves up in Z direction? See file and video please to see the issue. I know Marissa noted that this may be just a Marionette problem that was being looked at. Thanks Edited July 2, 2016 by Alan Woodwell Quote Link to comment
AlanW Posted September 16, 2016 Author Share Posted September 16, 2016 Appears that in 2017 this doesn't happen in iso view but still does if you use Sht + U which is the walk through mode but you would never want to move things around in that mode. Quote Link to comment
Marionette Maven Marissa Farrell Posted September 16, 2016 Marionette Maven Share Posted September 16, 2016 Alan, Thanks for the update. We worked hard to figure out the best way to make sure that shifting doesn't happen with Marionette objects in 2017. I'll put a note in about walkthrough mode, although as you said, it's not common or advisable to move objects in that mode. Let me know if you run into it in other situations! I tested as far as I could, but you may find something I didn't! Quote Link to comment
