Davide
Older versions
Once installed VW 10, can we safely remove
all the previous genealogy of VW 9?
Thanks
If you want ...
The only real need I can see keeping an older version would be if you have old old files that haven't been converted to a newer version.
VW 10 can only convert back to MC 7 files. If you have files that are versions before that, convert them to a newish version of VW so they are versoin 7 or later .. then get rid of the old programs.
Otherwise, you might find yourself needing that file from 1994 .. and to get it to open in VW 10, you'll need to convert it to an earlier version before being able to convert it to 10.
Katie,
Very soon I will be upgrading to a new work station (G5) that only runs System 10+. Which versions of Vectorworks will run on 10 so I can open old files.
Bob Tiedemann
VW 9.5 and VW 10. All of the other versions are not carbon compatible and will require classic to launch.
