lolo66 Posted March 16, 2016 Share Posted March 16, 2016 Hi, I'm drawing an elevation of a wall and i'd like to use the door program to save time. Is there a way to rotate the door so that it sits in my elevation? I've tried using the rotate 3D tool but it won't let me rotate the door plan. I'm sure there's a simple solution, apologies as i'm new to this! Many thanks, Lois Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 16, 2016 Vectorworks, Inc Employee Share Posted March 16, 2016 If the door is inserted into a wall, it will align with the wall direction. If you place it NOT inserted into a wall, you can use the regular "Rotation" field near the top of the Door's Object Info palette to rotate it in place. Quote Link to comment
