Patrick Fritsch Posted September 23, 2015 Share Posted September 23, 2015 Attached are images of the same model in 2015 and 2016, I would like to know how to adjust the following in 2016: 1.Set the Open GL edges to black as per the 2015 image. 2.Set the Open GL line edge line thickness to appear thinner, it's currently set to 1 pixel but it's visually looks like more I think. Any help! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2015 Vectorworks, Inc Employee Share Posted September 23, 2015 What quality do you have that OpenGL set to an is anti aliasing enabled in 2016? Quote Link to comment
Patrick Fritsch Posted September 23, 2015 Author Share Posted September 23, 2015 Attached are the settings, there does not appear to be any visual changes on the screen if I play with the "detail" and "anti-alias" settings ? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2015 Vectorworks, Inc Employee Share Posted September 23, 2015 Sorry just re-looked at the images, likely you will want a Renderworks mode with edges enabled or render OpenGL in a higher DPI viewport to get cleaner lines. The pixellation you see is likely a result of a standard res display, OpenGL is tied directly to the screen resolution when you render on a design layer. The greying is OpenGL trying to compensate for smaller lines than you can display per-pixel. Quote Link to comment
Patrick Fritsch Posted September 23, 2015 Author Share Posted September 23, 2015 So 1920x1080 on a 21" monitor is low res now...jeez gosh, I have a flintstones TV now. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2015 Vectorworks, Inc Employee Share Posted September 23, 2015 Yeah it was painful and quick, it was a rough transition but came suddenly after 2K and Retina became common: Quote Link to comment
