Copy and Paste causes a crash
Hi, I have 2 drawings open one the main file and another with random details to use.
When I select and copy details from the details file to the working file, I get questions about class visibility, turn on the classes etc, accept those then the program crashes.
This has happened a few times with different files and continues after a reboot.
I have resorted to the new layer import method which has worked in the past, but even now importing a layer through this process crashes the program.
Has anyone else observed this behaviour? or is it a bug.
An update, Well, after 10 restarts and trial and error, I have nailed so far to one group of geometry for a wall cross section.
I can select other details on the page and it will not crash, apart from this one random group.
If I ungroup all objects at the highest level, then I can cut and paste. Leaving one thing grouped causes a crash.
Send the file to Tech support I had a problem with a file and sent it to them and within a few days they found the problem, tapered extrusions that caused a crash as soon as I tried to render a viewport.
They told me what to delete and all was good.
They are great!
  • 3 weeks later...
