The Cantor Posted February 11, 2015 Share Posted February 11, 2015 Blended screens, when inserting the projectors, just stalls and gives me the dreaded spinning color wheel. 16:9 never resolves. 4:3 finally appears after a real 5 minutes. Any thoughts? Quote Link to comment
C. Andrew Dunning Posted February 12, 2015 Share Posted February 12, 2015 Thomas - A few questions: Are you having trouble with both the Landru and the Spotlight versions? 1 or the other? If the Landru version, what is the build # at the bottom of the OIP? Does this happen with all files or 1 in-particular? If 1 in-particular, would you post or send me a copy of the file so I can take a look? Quote Link to comment
The Cantor Posted February 12, 2015 Author Share Posted February 12, 2015 I sent a note to Service Select.I was using the Spotlight version, have not had a chance to install your version (I have it, just not enough time). I later exported the file as 2014. Reopened in 2014, and the blended screen worked fine. Just realized that Your version is what I am using in 2014! I just sent you the file at cad@landrudesign.com Quote Link to comment
The Cantor Posted February 12, 2015 Author Share Posted February 12, 2015 Found the problem. Had a Resource Name Issue. Got a nasty gram that showed up (after 10 minutes of spinning ball)that said I had a name conflict of a symbol. I changed the name, and the projectors appeared! Actually sitting in our Saint Louis Vectorworks Group meeting as I type this... Quote Link to comment
C. Andrew Dunning Posted February 12, 2015 Share Posted February 12, 2015 I'm glad all is working, now! Have a good one! Quote Link to comment
