To create a vector path for cutting text (laser or waterjet), I usually trace each letter with tangent arc polyline. Cutting tool software seems to accept only Corner vertices and Arcs, no bez or spline. Required format is usually DWG or DXF, often an old version.
Wish 1: An option in Vectorworks for convert text to poly with arc points instead of bez. This means more vertices, so a deviation tolerance setting would also be appreciated. Note: Poly Smoothing, Arc command does not work well for this. Tracing is better option.
I now have a library of a several traced fonts. Need Century Gothic for first time, so thought I would see how the text converts in VWX 2015. Same as it ever was.
Key in the text, Convert Text to Polyline (yields Corner and Bez points), scale as nec, export to DWG, then check the results by Import DWG.
The imported shapes have very little deviation from the exported shapes (Good!)
Somewhere in there all the corner vertices double up and return as stacks. (Bad!)
Wish 2: Wish that stack didn't happen.
Note: My arc polyline traces do not yield stacked vertices in the dwg round trip.
Benson Shaw
-B
3 answers to this question
