John Whyte Posted November 5, 2014 Share Posted November 5, 2014 Is there a way to draw tapered wall thicknesses in vectorworks using the wall tool. Ive taken a screenshot of what im trying to achieve. Quote Link to comment
Haydenovative Posted November 6, 2014 Share Posted November 6, 2014 Hi John, I've had a little play, the only sort of solution I have (And I hope it points you in the right direction) is in the spotlight > Architectural > Create Wall Projection If you draw a triangle of the wall you want on top of an area of wall, select both and create the projection it can create a wall with a feature that in 2D at least looks correct. I would imagine an architect would have more to say on this. HTH Quote Link to comment
mike m oz Posted November 6, 2014 Share Posted November 6, 2014 The Pillar command can be used to create odd shapes that walls will join to. The Pillar method works fine as long as you don't need components or doors and windows in those walls. Quote Link to comment
