Josh Schulman Posted October 20, 2014 Share Posted October 20, 2014 So I'm working on this project and I have discovered that some of my objects are see through even though they don't have a texture applied to them. I made the text using the "Convert Text to Polylines" tool then I extruded the letters .1" I know that the letters aren't in the wall that they are next to. The really crazy thing is that the letters don't show through when in different viewing angles, just this one. Any help would be great. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 20, 2014 Vectorworks, Inc Employee Share Posted October 20, 2014 Sometimes that just means the letters and the surface they are on occupy the same plane, so they will show through on occasion at certain angles. this is fixed by just moving the letters off the surface slightly. However, I cant really tell from just that screenshot, if you can post that geometry in a test document here or email the original file to tech@vectorworks.net I can take a look. Quote Link to comment
Josh Schulman Posted October 21, 2014 Author Share Posted October 21, 2014 Here is one of the pieces that is rendering oddly. I'm pretty sure that the extruded text isn't poking through the back end of the object behind it but maybe I'm wrong. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 21, 2014 Vectorworks, Inc Employee Share Posted October 21, 2014 There appear to be two panels (the large background rectangle) in the same location. One with a glass texture and one with a solid "White Dasher" texture. These objects being in the same location seem to be conflicting over whether the area should be transparent or not. if i move the glass textured extrude away from the white dasher textured extrude, the odd behavior seems to stop. Quote Link to comment
Josh Schulman Posted October 21, 2014 Author Share Posted October 21, 2014 Ahh, I see. JimW, thank you so much! Quote Link to comment
