Viper x Posted January 14, 2003 Share Posted January 14, 2003 I have created a new new class in a new layer and the plant symbol appears fine but I can't turn this class to invisible, what am I doing wrong please ? Thanks Viper x Quote Link to comment
Guest Posted January 14, 2003 Share Posted January 14, 2003 You should be setting a class to invisible thru the classes dialog box. Select the class and click on the white diamond in the dialog box. Make sure this class is not your current active class before doing so. Quote Link to comment
Viper x Posted January 14, 2003 Author Share Posted January 14, 2003 quote: Originally posted by Katie: You should be setting a class to invisible thru the classes dialog box. Select the class and click on the white diamond in the dialog box. Make sure this class is not your current active class before doing so. Katie, I am turning off the diamond as suggested, but it is not becoming invisable. Can you explain " current active class please " as the class I am trying to turn off is the class ie plant symbols that I am currently placing on the drawing. ? Thanks for your paticence with a Vector works duffer Quote Link to comment
Viper x Posted January 14, 2003 Author Share Posted January 14, 2003 Got it ! I am a worry, it must be the heat and bush fires over here at the moment that is making me dozy Thanks for you quick reply Katie. Quote Link to comment
