renderworks
If you go to View > Rendering, are the various Renderworks modes grayed out?
If so, you will need to remove the broken installation:
http://kbase.vectorworks.net/questions/1105/Uninstalling+Vectorworks
Then reinstall with your current serial number. Make sure to patch to the latest available service pack immediately after installing, before you open Vectorworks for the first time:
http://www.vectorworks.net/support/downloads/product-updates/
You may have a different installer than the one we use here.
Sorry for the inconvenience but you should contact your distributor directly for a localized version download link. I don't want to give you the wrong one inadvertently.
If you have Service Select your correct version will be listed here:
http://serviceselect.vectorworks.net/downloads/current-vectorworks-release
what is a broken installation and why should all of a sudden stop working
just out of curiosity ?
I have seen Renderworks flat out vanish from some user's machines. I have never been able to reproduce the issue on either their or my end after it occurs. I do not know the cause, but the only solution has been a reinstall.
I have not had the issue recur for anyone, which is both good and bad, since it saves them another uninstall/reinstall but doesn't allow us to find the cause.
