Hippocode Posted August 25, 2014 Share Posted August 25, 2014 (edited) Hi, I've been working on a vectorworks piping run module and was wondering if there was some public interest for it. Currently it features a 2D+3D path based drainage object which is close to completion. Eventually this module will create any pipeline needed in construction (domestic water, heating, gas..) The drainage plugin main features: • Easy automatic connections between segments, even within segments. Both variants can connect to eachother. • Automatic pipe dimensioning based on user-input( from worksheet, symbol or manual input ). • Insulation options • External file based material roughness and available diameters. • Both objects have a lot of visual options in 2D/3D customizable by classes. • 3D • IFC export • ... the following updated video shows about everything that can be achieved with it: https://www.youtube.com/watch?v=yF26ajstBJI DEMO PLATFORM: windows and MacOs VECTORWORKS: 2013-2014 The demo has 3 restrictions that allow you to explore all the plugin features but prevents you from using it properly on a project: • It will prevent you from creating more then 3 objects. If you do, one of the previous placed objects will be deleted automaticly. (Don't bother grouping/locking) • It will add some random characters before/after the diameterlabel on the drawing. • Its limited in time until end 2014. The download package(NL/EN) includes: • Installation instructions • A user manual. • The plugin • an example VWX file with some predefined classes and 2 worksheets(Device sheet + quantity sheet). Download here: https://www.dropbox.com/sh/7r3mw7wh6f5y3pn/AADM3SMas6fesIPDK7Pt1Uy2a?dl=0 If you take the time to test it out I'd appreciate any comments, suggestions, bugs.. It's still a work in progress. Edited October 6, 2014 by JimW Quote Link to comment
Ilay Posted August 28, 2014 Share Posted August 28, 2014 (edited) Hello Wouter Great tool! I have question: has your tool feature to make gradient(different level between tie-in or pipes)? Calculation of pipe dimensions based on user-input( from worksheet, symbol or manual input ). And with my first question, will it be into table data...dynamic data(pipe network and table specification) too? Edited August 28, 2014 by Ilay Quote Link to comment
Hippocode Posted August 28, 2014 Author Share Posted August 28, 2014 has your tool feature to make gradient(different level between tie-in or pipes)? The 2D plug-in allows you to choose a slope as percentage which is used in the calculation of the drain but the segment will always be visual horizontal. If you'd like to create segments with vertexes that shift in height there is a 3D variant that does exactly the same as in the video but allows you to work in 3 Dimensions. The 2D variant will also get the option to be converted into the 3D variant, based on an angle. This makes drawing a complex 3D pipe much easier. I've decided to create the same tool in 2D as well as in 3D because 3D doesn't offer the extended editing options of vertexes as you have in 2D. Calculation of pipe dimensions based on user-input( from worksheet, symbol or manual input ). And with my first question, will it be into table data...dynamic data(pipe network and table specification) too? For each drain you create, you can select a flow ( liters /second ). This flow can come from text fields in the oip, from predefined "devices" as a drop down list (from worksheet) or from symbols (with recordfields attached). You can always overwrite the diameter. As you saw on the video, connected objects update eachother on any change. Changing or moving something in a complex chain will update the whole chain. All of what is drawn can be loaded into a worksheet with all the specifications visible the same way you use reports for other objects. Quote Link to comment
Ilay Posted August 28, 2014 Share Posted August 28, 2014 Super, thanks for info! Quote Link to comment
Fredrik Posted September 17, 2014 Share Posted September 17, 2014 I would also like to see this in my tool palette. Is it going any further? Just updated to 2015 and can't find it there. Quote Link to comment
Hippocode Posted September 17, 2014 Author Share Posted September 17, 2014 I would also like to see this in my tool palette. Is it going any further? Just updated to 2015 and can't find it there. Its a custom pio so its not shipped with vectorworks. I'll post an update and a demo the coming weekend as I've almost got the 3D variant finished with some more functionality. Quote Link to comment
mike m oz Posted September 18, 2014 Share Posted September 18, 2014 Wouter, it looks very interesting. Some queries: - does it model falls for the 'plan view' runs? - will it model vertical drops and stacks? Quote Link to comment
Hippocode Posted September 18, 2014 Author Share Posted September 18, 2014 Wouter, it looks very interesting. Some queries: - does it model falls for the 'plan view' runs? For now only for vertical segments "90?". An arrow(symbol) indicating the direction will be drawn in plan view on the vertex where the vertical segment begins. - will it model vertical drops and stacks? Vertical drops as answered above. This can be drawn with the 3D variant. Not sure what you mean with "stacks" ? Quote Link to comment
mike m oz Posted September 19, 2014 Share Posted September 19, 2014 To be usable in 3D it needs to have the ability to model the falls in plan runs. A stack is a vertical plumbing pipe (usually in a duct) that the plumbing runs at each floor connect to. Quote Link to comment
Hippocode Posted September 19, 2014 Author Share Posted September 19, 2014 To be usable in 3D it needs to have the ability to model the falls in plan runs. A stack is a vertical plumbing pipe (usually in a duct) that the plumbing runs at each floor connect to. Oh yes you can. You can create unlimited connections between the 2D and 3D variant of the object. The 3D variant can be used to create the vertical ones or any other combination. The 3D variant behaves as a 3D polygon so you can go nuts with it. I'll also update the video tomorrow showing the answer to all these questions. Quote Link to comment
Hippocode Posted September 22, 2014 Author Share Posted September 22, 2014 (edited) I've had Jim help me update the first post. The description has changed, a new better video showing off all features is added and the promised demo. EDIT: Clients seem to have problems installing the demo so I've removed it for now. It seems to be a weird problem of missing DLL's I'd like to resolve first. Edited September 23, 2014 by hippothamus Quote Link to comment
Hippocode Posted September 24, 2014 Author Share Posted September 24, 2014 The demo download is now available and working. Quote Link to comment
Ilay Posted September 24, 2014 Share Posted September 24, 2014 Wouter, thank you! (will be possible to compile for VW 2015, 64-bit?) Quote Link to comment
Hippocode Posted September 24, 2014 Author Share Posted September 24, 2014 Wouter, thank you! (will be possible to compile for VW 2015, 64-bit?) I just noticed the sdk 2015 is available for download! I will also port it to 2015 but I'll first get started on the mac version for 2013-2014. Quote Link to comment
Hippocode Posted October 6, 2014 Author Share Posted October 6, 2014 I will also port it to 2015 but I'll first get started on the mac version for 2013-2014. The MacOs plugin has been added to the download folder. The plugin works in vectorworks 2013 + 2014 on both platforms. Quote Link to comment
