Copy stories
If they're going to be the same objects in the same relative locations to each other, its easiest to just duplicate the entire layer in the organization dialogue box, then adjust its heights and rename it.
If there is a lot of other geometry on the layer you don't want to duplicate, you can select the walls/windows/doors, duplicate in place, then just assign them to the new layer in the object info palette.
A problem with this method is that the windows & doors don't always set themselves within the walls that could already be drawn in that location.
