Viper x Posted December 19, 2002 Share Posted December 19, 2002 Could you please tell me the tricks to successful importing of DWG into VW10 that has been originally drawn in Archicad. A simple step by step at both the saving of the original file in Archicad ready for exporting and how I should best open it in VW please. Thanks Viper x _ Quote Link to comment
Guest Posted December 19, 2002 Share Posted December 19, 2002 Go to file> import > import dxf dwg. Make sure you set the units to the correct unit measurment. Where it has the Model Space Scale option -- select This Scale. This will bring in the drawing at the correct scale used in VW and resize appropriately to the scale of the layer. The scale button basically changes the scale of the layer the drawing is importing to. Esentially, if you set the layer scale correctly in the new VW document, then you don't need to set the scale iwth the Scale button. The graphic attributes tab is up to you. I leave it as the default settings when importing, but you can change it from color to black and white if you'd like. That's really about it. The importer/trasnlator will do the rest of the work for you. Quote Link to comment
Viper x Posted December 19, 2002 Author Share Posted December 19, 2002 Thanks Katie, a few problems I get : 1. The drawing loads in a fragmented way, bits here and there. 2. Plants created in Archicad I think come in made up of lines rather than symbols. 3. The current drawing I imported is very slow to work in, refreshing is slow as I pan or carry out commands. 4. Should I be specifing a certain way the DWG should be saved for me in Archicad before they send it over, to stop the problems above ? Thanks Viper x Quote Link to comment
Guest Posted December 19, 2002 Share Posted December 19, 2002 Well .. pieces of the drawing over the place can be a few different things. One being, that's the way it's drawn. If you want me to look at it, I can certainly do that. Send the file to tech@nemetschek.net attn:Katie and I'll take a look and see what's going on. Quote Link to comment
