Event ID's
Hello,
Still trying to unraffle the Events-mysteries ...
The famous page on the VectorLab-site shows all kind of Event-ID's in the CONST-block.
Is there anywhere a list that sums up all these Events-ID's?
Or are they all here?
The VFR pages that handle Events link us back to page mentioned above, so, no help there.
Where do these constants come from?
These are the pio events that I have worked with and tested successfully:
kResetObjectEventID = 3;
kInitObjPropEventID = 5; {Initialize events}
kButtonPressEventID = 35; {Handle button clicks}
kOnWidgetDefEventID = 41; {Handle widget visibility & custom popups}
kObjAddStateEventID = 44; {Handle changes to parameter values}
There are also events recently introduced for tool objects but I have not tested them yet.
BTW, all these constants are defined in the C++ SDK if you want to adventure and look at all of them
Yes, the SDK is the key for finding all constants. The include files starting with "MiniCAD" will give you most of what you need. One has preference and object-variable constants, and another has PIO related constants. There are a few PIO and Tool events that never get raised for VS.
Note that vs constant and variable names are limited to the first 20 characters, so if you simply copy and paste some of the constant blocks, vs will read long constant names as the same and throw an error.
You can download the SDK through the Vectorworks.net support section.
HTH,
Josh
