Batch change attributes of PIO's?
Of course there is a way ;)
I did this recently
- Selecting: Custom Modification> by object type.
- Brings up "Properties" dialog that is like the OIP but has a button for Attributes.
- Click on that and set line values as you like. If you're not sure what you'll want then make a new class and use that.
The one thing you can't do is change setting to "by Class"
This works the majority of the time, but there are some situations still where if the objects are within groups or viewport annotations that they may not come up in Custom Selection/Modification.
These are going away more and more now, but there are still cases where it doesn't have full access to all objects.
Edited by JimW
