Window Classes how do they work?
Confirmed here. Classed every single item and shut it off as a test, the exterior trim just doesn't disappear no matter what I assign it to. They seem tied directly to the Window's class visibility.
Same with Interior trim as well, it looks like.
Submitting as an issue now.
Edited by JimW
Peter I assume you mean the Attributes Palette not the OIP! (that was actually the culprit in 3D in this case)?
Jim it would be even better if you could submit a wish for it to also work in Top/plan view because I actually need to hide the trim in Top/Plan and have it showing in 3D. Another solution would be for the trims etc. to also be connected to the Plan Detail checkbox in the OIP.........
Edited by Vincent C
