Jsleutel Posted October 28, 2002 Share Posted October 28, 2002 These are a couple of thing I have noticed since installing v10. 1. The background behind dimensions has increased significantly. On drawings where I had dimensions close together it distorts the look of the drawing. 2. I am unable to get the fill to turn off behind dimensions. Note: There seems to be an additional fill box behind the dimension which is larger, obstructive, & unchangeable. 3. When I adjust text size the current size is not highlighted when I open the pull down widow. I then have to go up and highlight it before I can change the size. Has anybody else noticed these problems? Quote Link to comment
Guest Posted October 28, 2002 Share Posted October 28, 2002 In VW Prefs (File, Prefs, VW Prefs) click on Display tab. Put a checkmark in "No Fill Behind Text" checkmark box. As for the font size thing, what type of font are you using? What version of VW are you using? Quote Link to comment
Vectorworks, Inc Employee Bruce Ferguson Posted October 28, 2002 Vectorworks, Inc Employee Share Posted October 28, 2002 Not being able to turn off the fill behind the dimension happens when the text offset is 0, such as when you use ASME dimensions. This is a known bug. Quote Link to comment
Jsleutel Posted October 28, 2002 Author Share Posted October 28, 2002 When did this become a bug? I never had this problem in v9. These dimensions seem to have two fills, I think you can turn off the fill but the second fill is unchangeable. My existing drawings are distorted when I convert because the second fill is bigger than the standard fill. Quote Link to comment
Vectorworks, Inc Employee Bruce Ferguson Posted October 29, 2002 Vectorworks, Inc Employee Share Posted October 29, 2002 The second fill was added for v10. It is just there when the text offset is 0. It was added because of a complaint that the break in the dimension line was not large enough for ASME dimensions. It's size is a little larger than the text fill in both directions. I think the problem you're seeing with its size would be solved if it was only bigger in the direction of the dimension line. We will investigate this. Quote Link to comment
