taoist Posted July 27, 2013 Share Posted July 27, 2013 Connect/Combine tool does not work for 3D objects. Is there such a beast? If not, what tool(s) do we have? Quote Link to comment
taoist Posted July 27, 2013 Author Share Posted July 27, 2013 (edited) Just discovered Trim and Stitch in 3D Powerpack. Acts like split tools 2nd mode except you do not draw a line to create the split. Select the object(s) to trim then the boundary. Then select the cut portion(s) that you don't want and delete. Would be great not to have to select what you don't want. Think automatic trim. Edited July 27, 2013 by taoist Quote Link to comment
Gytis Posted July 27, 2013 Share Posted July 27, 2013 Connect/Combine tool does not work for 3D objects. In fact, Connect/Combine works with some species of 3D objects, namely NURBS curves and surfaces. Quote Link to comment
taoist Posted July 27, 2013 Author Share Posted July 27, 2013 Gytis, Thank you, I stand corrected. Quote Link to comment
