kendal23 Posted April 29, 2013 Share Posted April 29, 2013 Hi I have been trying to fix this problem for a long time! I have drawn each contour up as a 2D polygon and have extruded them sitting on top on each other. The problem I have is when i go to render them some of them render as solids and some only render the outer line.. I dont understand what the difference is between them and why some are rendering and some are not.. Quote Link to comment
Dieter @ DWorks Posted April 29, 2013 Share Posted April 29, 2013 (edited) - Make sure the 2D polygon is closed. - Make sure that everything is set by class and that you have a texture applied to the class. - Make sure that the extrude has a solid fill. Edited April 29, 2013 by DWorks Quote Link to comment
kendal23 Posted April 29, 2013 Author Share Posted April 29, 2013 Thanks,when people say closed I thought it meant all the lines connected however I then noticed there is a 'closed' button in the object info, It is working now Quote Link to comment
Pat Stanford Posted April 29, 2013 Share Posted April 29, 2013 Closed does mean with all the lines connected. But it is possible to draw a poly and not quite get the start point and end point to be exactly coincident. If that happens, even though it looks closed to your eye, the computer does not realize it is closed. The closed button fixes this by drawing an extra line between the first and last vertices. Quote Link to comment
Dieter @ DWorks Posted April 29, 2013 Share Posted April 29, 2013 Closed does mean with all the lines connected. But it is possible to draw a poly and not quite get the start point and end point to be exactly coincident. If that happens, even though it looks closed to your eye, the computer does not realize it is closed. The closed button fixes this by drawing an extra line between the first and last vertices. A closed polygon can also be open, if one line is set to hidden. I think this is something misleading and confusing, even with polygons converting to polylines... Quote Link to comment
