2 lights should appear as one light in Legend-list. How?
JayJay
Hey Guys
i work in Spotlights with 2 fixturetype - A HUNG and a STAND Symbol.
That means for every Symbol / light in my library i have 2 to choose from.
Therefor when i printout the legend list i do get the count for hung and stand lights regarding to my file.
Is there a way to produce a hung symbol and a stand symbol so that the legend is showing only the "main" fixture?
e.g used in file:
Intellaspot hung - 3
Intellaspot stand - 3
legend is showing:
Intellaspot - 6
I hope u know what i mean
thank u
Jay
I don't have a symbol for Hung & Stand. I use 1 symbol and change the 3D Orientation. Select the symbol and near the bottom of your OIP should be a check mark for set 3d orientation. If you click that you should get options that allow you to rotate it in 3d.
If you were going to try what I suggested above, use 1 symbol, and put it in your document. Change the 3D orientation, then save that as a new symbol. This was you original Symbol is being referenced within the new symbol. When I get a chance I can try this out to see if it works.
hey Chad
yeah...i know the 3D orientation issue.
This was also thought doing it like that.
I just played with it.
But my default hung fixtures do have clamps on the base.
when i just rotate the fixture, then the clamps are still there and not needed when standing on the floor.
the other way is not to use clamps :)
