Sam Lee Posted January 10, 2013 Share Posted January 10, 2013 Hi, we do allot of interior design work, and for the setting out part of it ie. light fitting ect symbols are really useful. But for furniture its not so great, because although we need the pieces to look the same, the dimensions can change.. ie. we have a chair symbol but its 100 x 50 cm were we need it 150 x 60 cm. Would we be able to keep it as a symbol and just change the dimensions of individual instances ? thanks Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted January 10, 2013 Vectorworks, Inc Employee Share Posted January 10, 2013 Which version of Vectorworks are you using? It is possible to scale individual instances of symbols. Just select the symbol and on the object info palette you can change the scale type - symmetric or asymmetric. Then, you can choose scale factor for each direction. Alternatively, you can reshape the symbol on the plan. Hope that helps Quote Link to comment
