machwave Posted March 1, 2006 Share Posted March 1, 2006 How do I make a pointed 3D cone with an elliptical base, rather than the usual circular base? Since the taper angle varies around the ellipse, the Tapered Extrude function doesn't work. Quote Link to comment
mike m oz Posted March 1, 2006 Share Posted March 1, 2006 Tapered extrude works for me - takes a bit of trial and error to get the parameters right, but it works. Quote Link to comment
Kaare Baekgaard Posted March 1, 2006 Share Posted March 1, 2006 There is more than one way. The easiest is to use the cone object or cone tool. Make a regular cone. Convert to nurbs group. Reshape from top view, so the x-and y values match the elipse, you want. Ungroup and Add Solids. Or... make an elipse. Convert to nurbs curve. Add a 3D locus in the center of the elipse. Move the 3D locus up. Loft bvetween the locus point and the eliptical nurbs curve with the 'create solid' option on. Quote Link to comment
machwave Posted March 1, 2006 Author Share Posted March 1, 2006 Thanks for the tips. I'll give them a try. I'm an infrequent user and am slowly learning the basics. Quote Link to comment
