gester Posted November 9, 2012 Share Posted November 9, 2012 hi, i've set my project with stories and layers to the aimed levels, but i've forgotten to check the project origin. after i've made the site model it turns out the terrain z-coordinates are some 6 km above the real ones (and they display incorrectly). the x and y coordinates are way out of control either. is it possible to bring the whole lot to the project origin somehow? thx in advance, rob Quote Link to comment
gester Posted November 9, 2012 Author Share Posted November 9, 2012 ok, the x-y coords are now fixed. but i have no idea for the z-coordination fix... rob Quote Link to comment
VincentCuclair Posted November 9, 2012 Share Posted November 9, 2012 First make a copy of the file First change the top or bottom most Story elevation to the new elevation and choose the option to move the other storys too. Next select everything that's left behind ( you'll need to set layers to show/snap/modify) and move by points in a side view to the correct height. That should take care of it. Not sure but an option could be to reference the existing file into a clean new one move the VPs to the new correct position and merge it into the new. Haven't tried this so i don't now what will happen..... Quote Link to comment
