Chris Fleming Posted October 26, 2012 Share Posted October 26, 2012 I've finally done an upgrade! After years, I've moved from VW2008 to VW2012 (alas, still a version behind!). Is there a way to bring my custom, intelligent title block into 2012, or do I have to recreate it? Quote Link to comment
Dieter @ DWorks Posted October 26, 2012 Share Posted October 26, 2012 Sure, depends on what it is... Quote Link to comment
GWS Posted October 26, 2012 Share Posted October 26, 2012 Well everybody says you should recreate from scratch....but I have never had any trouble doing this...ALTHOUGH I have only ever done it 1 year back (not 4) so it may not work. Goto Applications>Vectorworks 2008>Libraries>defaults>Sheet Border-Title Blocks and open the file with your Title Block in it. Do the same thing with your 2012 version and open 'Custom Title Blocks' with your 2012 file active select the 2008 file in the resource browser and select the record and import it and do the same with the title block. You can then drag the Title Block onto the 'Custom Title Block' and it will be available next time your set up a drawing border. --Basically you could just copy and paste the record and title block from one file to the other which may be simpler!!-- This may not work with such a big gap in versions but it's worth a try. Quote Link to comment
Dieter @ DWorks Posted October 27, 2012 Share Posted October 27, 2012 Well everybody says you should recreate from scratch....but I have never had any trouble doing this... If you have a custom library, it should be no problem to just batch convert them to the latest version. I Always do this and I never had any problems except for some textures when they changed the rendering engine. Quote Link to comment
Chris Fleming Posted November 7, 2012 Author Share Posted November 7, 2012 Thanks Guy! Worked like a charm! Quote Link to comment
