Fucile Posted August 26, 2012 Share Posted August 26, 2012 I have inserted 2nd floor windows in gable walls which were created by fitting first floor walls to roof. I'd like to assign those to a different class, to control visibility in top/plan view. When I try to do it in the object info palette, nothing happens. Anyone know a work around for this? Quote Link to comment
VincentCuclair Posted August 27, 2012 Share Posted August 27, 2012 (edited) You probably need to switch off Auto classing in the Standard Naming dialog (File>Document Settings) Edited August 27, 2012 by Vincent C Quote Link to comment
Majic Posted August 28, 2012 Share Posted August 28, 2012 I find that auto-classing works great until one wants to have some of the standard auto-classed objects in special classes, such as you describe Fucile, or such as to identify objects that are existing to remain or demolish, etc.; then un-checking auto-classing is preferred. Just remember, if you later want to use the auto-classing feature, select the No button when the dialog "Do you want to auto-class all existing auto-classing objects now?" appears! Quote Link to comment
Christian Fekete Posted September 26, 2012 Share Posted September 26, 2012 I think that the issue is having the window on the 1stfloor walls and looking at the second floor plan where they will not appear. Am i understanding correctly? Quote Link to comment
