Hakan 0 Posted March 29, 2012 Anybody can explain how I can extrude / create a plot with 2D levels(text) to a 3D landscape , mesh ?? thanks in advance Quote Share this post Link to post
Tamsin Slatter 503 Posted March 29, 2012 Well, you need to convert those 2D shapes into 3D, but you want to retain the 2D. I would suggest you use Landmark > Objects from Polyline to convert your 2D shapes to Hardscapes, Landscape Areas and Walls. Each of these will have a 2D and 3D component and can be set at any Z value relative to the design layer. To create a mesh, you need levels measured on site, in a 3D format, which you can import and then create a site model. I hope that this will help you get started, but what you have asked is really quite a huge question and not something that can be answered in a quick forum post... But I do hope it helps you to get started. Quote Share this post Link to post
Hakan 0 Posted May 20, 2012 Tamsin , Thanks for your help . At least,I started to understand the logic . Quote Share this post Link to post
