Yovav Posted March 12, 2012 Share Posted March 12, 2012 Hello I'm trying to print a project presentation in a print shop. We are exporting the project to PDF and JPEG, and in both cases we are getting prints that are very different from what we see on the VW screen. What is the best way to sync the on-screen colors to the print-shop printer? Is there an option to correct colors in VW? We are using VW 2010. Thanks Yovav Quote Link to comment
cad@sggsa Posted March 12, 2012 Share Posted March 12, 2012 Does Printscreen do the same? Ctrl+Print Scrn> Paste in any application like Photoshop,paint etc. Quote Link to comment
Yovav Posted March 12, 2012 Author Share Posted March 12, 2012 Dear Carl All of the 3 (print screen, PDF, JPEG) looks a bit different, on screen. Minor changes. In print the difference is much bigger between the formats. Yovav Quote Link to comment
Kizza Posted March 14, 2012 Share Posted March 14, 2012 do you have adobe acrobat? (not reader) What is your hardware specs? Quote Link to comment
cad@sggsa Posted March 14, 2012 Share Posted March 14, 2012 This might not be VW problem I know from experience and help from a Graphic Designer that you can never go on what is shown on screen as the screen resulotion and colors are not the printing colors. This is the reason for print proofs when design goes for print. It is the printer that determans the color of the print. Then again they should not differ that much but will never be exact. Would help if you add some info regarding what you use like I have in my Signature, Im sure it will help the more advanced members on here like the Mods to give a correct solution on your problem Quote Link to comment
Kizza Posted March 15, 2012 Share Posted March 15, 2012 This problem could be: 1) VW colour profiling issue 2) Uncalibrated monitor Difference should not be that great. I bet it's an RGB(VW) to CMYK(print shop) colour shifting issue. If it is, then it may be because VW lacks the capability to let you choose what colour profile to use in a file. Therefore, you need to try and correct outside of VW. If you have Acrobat, then there are several save options you can try - in effect, you are using Distiller to create the pdf (not VW). Quote Link to comment
Guest Posted March 15, 2012 Share Posted March 15, 2012 Tell the clients to "Colour Pot Your Kitchen" (CPYK) costs $20 from Dulux paints Quote Link to comment
