Craig D.S. Posted February 9, 2012 Share Posted February 9, 2012 (edited) Greetings I'm slowly starting to get the hang of some of this different then what I'm used to program (VW11), having just now started on my first whole project with it. I need to show the existing (Church) building on the 3d site plan to examine the steep grade change for optimum new addition placement. I obtained the existing site with the elevation points as a scanned document The site plan is now drawn with the plot lines and hardscapes and manually entered 3d stake objects etc. The problem is the elevation points are in metres above sea level (256), and the plan is down at z=-6" What is the best way to resolve the present quandry so that the building FP is at the right spot elevation and the property line follows the respective terrain? Is it better to make the 2d DTM then add the 3d stake objests? I will try to show some images as soon as i figure out how Edited February 9, 2012 by Craig D.S. Quote Link to comment
Craig D.S. Posted February 13, 2012 Author Share Posted February 13, 2012 I suppose I could just live with it and subtract the value of the Lower floor level elevation point from each of the elevation points, lowering the whole site model respective down to that level instead of sea level Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted February 13, 2012 Vectorworks, Inc Employee Share Posted February 13, 2012 If you put the building on a different design layer, you can change the elevation of that design layer so that the building sits where you want on the model. Alternatively, you can create a design layer viewport of the site model on a different design layer - and change the elevation of that design layer (hiding the original model). This will retain the heights as they are within the model, but move the view of the model so that it lines up with your model of the building. So, to summarise, either: Move the design layer the building is on or Create a design layer viewport of the site model and move that to meet the building. Hope that helps. Quote Link to comment
Craig D.S. Posted February 14, 2012 Author Share Posted February 14, 2012 I hear what you're saying... It may be advantagous to raise the ground level design layer up to the respective elevation point ASL, and the design layer the building is on down to its point above sea level ... Thanks Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted February 14, 2012 Vectorworks, Inc Employee Share Posted February 14, 2012 No problem! Quote Link to comment
