zuken86 Posted December 27, 2011 Share Posted December 27, 2011 How do I get the scale in drawing label to display a drawing's scale? "Actual Size" doesn't seem to go away! Thanks, Quote Link to comment
Kevin McAllister Posted December 27, 2011 Share Posted December 27, 2011 If you're using the drawing label on a sheet layer, you need to put it into the Annotations "layer" of the Sheet Layer Viewport. If you double click on the Viewport the edit options should come up, choose Annotations. Alternately you can right click on a Viewport and choose Edit Annotations. The drawing label is designed to show the scale of its current layer. The annotations "layer" is the same scale as the Viewport it is connected to so it shows the correct scale. Hope this helps. Kevin Quote Link to comment
zuken86 Posted December 27, 2011 Author Share Posted December 27, 2011 Thank Kevin! Quote Link to comment
