brbetten Posted August 25, 2011 Share Posted August 25, 2011 Have a drawing that I am circuiting, for some reason when I use the ganging tool it draws arrows at the end of each line connecting the two or three fixtures. This has not happened in the past. Any thoughts on how to lose the arrows at the ends of the lines. Thanks in advance! Quote Link to comment
michaelk Posted August 25, 2011 Share Posted August 25, 2011 Assuming you are using vw2011 and the stock ganging tool.... You may have found a bug. To fix it: 1. Make sure nothing is selected. Check that the OIP says "No Selection" 2. In the Attributes Palette make sure the arrows are turned off for both sides. 3. Tools > Utilities > Reset All Plug Ins. Accept the ominous warning. If the drawing is really big and you don't want to risk having it go through every instrument and take a long time, you can just select the affected ganging objects and force them to reset by changing any parameter in the OIP and changing it back. (i.e., click Show Label twice). The ganging tool seems to take on whatever the default marker setting is when it is inserted or reset. But the markers cannot be changed directly when the the object is selected. mk Quote Link to comment
