Shac23 Posted August 1, 2011 Share Posted August 1, 2011 Hello to you all, I have a stage with a focus point and i have a light set to it but when i render it i get a black beam. how do i fix it so i will see a white beam? Quote Link to comment
michaelk Posted August 1, 2011 Share Posted August 1, 2011 Make sure you have the light turned on (visualization palette) and not Draw Beam (object info palette). And you have to be in a render mode that will show light. If you want to see the beam make sure that fog is turned on, (and Distance Falloff is NOT "None".) hth mk Quote Link to comment
Shac23 Posted August 2, 2011 Author Share Posted August 2, 2011 Cool thanks. I got it to work with a Leko but when I try with a Color Blast it dosent work. Am I doing something wrong? Quote Link to comment
michaelk Posted August 3, 2011 Share Posted August 3, 2011 Looks like there is a mistake in the stock Colorblast 12 Symbol. This one should render a little better. mk Quote Link to comment
Shac23 Posted August 3, 2011 Author Share Posted August 3, 2011 I dont know why but I cant get this one to work. I opened the new color blast file and exported the symbol to the Color Kinetics library then I inserted it to the plot turned the fixture on and gave it a focus point but it still does not render. Quote Link to comment
michaelk Posted August 3, 2011 Share Posted August 3, 2011 Don't put the new symbol in the library. Bring it straight into your drawing. Make it active in the resource browser. Use the Replace with Active Symbol button in the OIP to replace the old symbols with the new ones. hth mk Quote Link to comment
