tamarindi 0 Posted July 31, 2011 The mirror texture reflects everything else perfectly. However, the BG image is "calculated" (through a window) at the end, so it skips the reflection in the mirror object. Any suggestions how to work this around? Quote Share this post Link to post
Farookey 0 Posted August 3, 2011 Hi... Have you tried HDRI BGs? They work pretty well with reflections that are behind the camera etc., as you can see the (sky) background behind you. Alternatively, I have done in the past, where I wanted a certain reflection (golf course fairway and vegetation in my case) and not the HDRI sky, I placed a large Image prop (showing the view I want to see in my reflection) behind the camera (or where ever the reflection comes from). If tweaked just right, you would get some realistic reflections. Stress on the LARGENESS of the image prop! I actually used a mixture of both methods for my scenes, but you should be able to do something similar with a standard BG as well... Is this what you were looking for? Quote Share this post Link to post
tamarindi 0 Posted August 6, 2011 Hi, HDRI and image props does reflect. BUT - what if the image is not an HDR? I still don't understand why simple image background would not reflect same as HDRI.... Thanks Quote Share this post Link to post
Horst M. 5 Posted August 7, 2011 (edited) Hi, As far as I understood: - a HDRI Background s a Dome and therefore reflecting in the Surfaces of the Object - a Backgorund is just ---> in the Back! so there is nothing to be reflected http://www.google.com/search?q=HDRI+textures&hl=en&client=safari&rls=en&prmd=ivns&tbm=isch&tbo=u&source=univ&sa=X&ei=k24-TqTsGsWh-Qb77MTDAg&ved=0CGMQsAQ&biw=1324&bih=760 I like this: http://itunes.apple.com/us/book/the-hdri-handbook/id413717022?mt=11 others sell paperones.. Regards Horst M. Edited August 7, 2011 by Horst M. Quote Share this post Link to post
