florag Posted May 26, 2011 Share Posted May 26, 2011 Hi, I'm using vectorworks 2009 (bit of a newbie) I'm trying to create windows using the window tool. I have managed to create a 6x6 pane window in the sqaure shape. But can't figure out how to do the same for the round window. I have attached a picture of the windows to show you what I am aiming for. Any help would be much appreciated, thanks Quote Link to comment
CipesDesign Posted May 26, 2011 Share Posted May 26, 2011 Select the Window, in the Object Info Palette (OIP) set the "Top Shape" of the window to "Round" (or as preferred) Quote Link to comment
florag Posted May 26, 2011 Author Share Posted May 26, 2011 Thank you!! One more question how do I create the 36 window panes in the square window and the 22 panes in the top rounded window frame? Thanks again! Quote Link to comment
CipesDesign Posted May 26, 2011 Share Posted May 26, 2011 Use the "Muntins" and set the number of horizontal and vertical as desired. If you can't find them please post back. Quote Link to comment
florag Posted May 26, 2011 Author Share Posted May 26, 2011 Thats brilliant, thanks. When i render the room (open GL) the window stays gray. Do i have to add a clear glass rendering texture to it? I thought inserting the window in the wall would cut the window shape through it...? Quote Link to comment
CipesDesign Posted May 26, 2011 Share Posted May 26, 2011 Click on the Settings button in the OIP. Go to Classes. Check which class the glazing is assigned to. Exit the dialog. Now go to the Class Setup dialog and make sure that the Class (from previous step) is set to use a clear glass texture, and that it's set to Use at Creation... Then re-render... Quote Link to comment
florag Posted May 27, 2011 Author Share Posted May 27, 2011 got as far as setting the class to 'clear glass texture' (couldn't find the 'use at creation' button) But re rendering and the window still disappears and leaves a grey wall. What other things to I need to check i've done...? Quote Link to comment
florag Posted May 27, 2011 Author Share Posted May 27, 2011 everything seems to be checked as visible on the 'navigation' tab. Does the jamb depth have to be the same as the wall (400mm) perhaps? Quote Link to comment
florag Posted May 27, 2011 Author Share Posted May 27, 2011 ahh think i've sorted it now, i don't think it was recognizing my walls as 'walls'! Thanks for your help! Quote Link to comment
CipesDesign Posted May 27, 2011 Share Posted May 27, 2011 Yes, you need to be sure that windows and doors are "in walls". There is a toggle called "Wall Insertion Mode" (above at top of VW's window) which enables/disables this... You can see if a door or window (or other) is in or not by looking at the object's description in the OIP. Quote Link to comment
florag Posted May 27, 2011 Author Share Posted May 27, 2011 thanks, yeah I'm steadily learning I'm onto stairs next ...i'm using a platform U shape stairs. But i wanted to create 3 or 4 platforms in between each set of steps to get up to the next level and it appears to only give one platform in the preview box.. Do you know what I have to change to do this? Quote Link to comment
CipesDesign Posted May 27, 2011 Share Posted May 27, 2011 Change the Platform to a Run (of stairs)... Quote Link to comment
Lec Posted June 27, 2011 Share Posted June 27, 2011 Hi, just to add to this - if I need to create a completely round window, how's that done? There seems to be no library at all for circular windows. I tried creating a half round and then using the mirror tool but it's no good. Then I tried to copy the half round and rotate it but still with no success. So, any ideas anyone?? Quote Link to comment
Farookey Posted June 27, 2011 Share Posted June 27, 2011 Hi... I do not believe this is possible with the standard VW window plug-in (If it is, someone please comment). I usually create a symbol of my 'completely round' window and 'convert' it to a window plug-in, so it reads as a window in wall, and not just symbol in wall... Quote Link to comment
Lec Posted June 27, 2011 Share Posted June 27, 2011 Ah, that's what I thought. Thanks anyway - if anyone is listening out there who makes symbols for VW please can you add round windows to the library. Thanks again Farookey. Quote Link to comment
