VinceHollywood Posted April 18, 2011 Share Posted April 18, 2011 I have designed a plot with multiple lighting positions and I am trying to figure out the way that you create viewports so that you can isolate each of the lighting positions off and display all of them on a separate sheet layer for the lighting crew to view. Can does anyone know how this is done? Quote Link to comment
michaelk Posted April 18, 2011 Share Posted April 18, 2011 Vince If your lighting positions are not stacked on top of each other, you can create a viewport crop to isolate each position. If they overlap, you will need to put each position on it's own layer or in it's own class and control the visibility in the VP. hth mk Quote Link to comment
