Hello Community!
This Thursday, October 21st, from 6 pm to 7 pm EDT, we will be performing an update on the Vectorworks Community Board. During this time, the site will be unavailable.
ISO pipe drafting
Does any one use VW 2011 to do ISO or spool pipe drafting? I can read piping and instrumentation diagrams, what I need is for someone to teach me a good technique for creating the spool fabrication drawings from the P&ID drawing.
I will gladly pay for your time or if anyone can direct me to courses or literature on the matter it would be much appreciated.
Peter, I use VW2011 to do ISO 3D piping system design for water treatment plant and mechanical systems. Really pretty slick except I have to use MicroStation V8I to produce the 3D PDFs that I need for client review. Chase me down with any questions.
Win Benbow
win@bwcsystems.com
Fittings and all equipment were modeled in Vectorworks.
3D PDFs can be created directly from a VW2011 DWG export but it takes a lot of rework in Acrobat to get it right. AutoCad can also produce 3D PDFs but it a bit harder to get the transparency working correctly (you have to assign it via materials, etc.).
MicroStation V8I just does a really slick job of conversion. You can open the DWG file (exported from VW), save it as a DGN (Microstion file), revise the layer data (classes) as needed and print out the 3D PDF model.
VW2011 does have some real problems when exporting DWG files with complex extruded polylines that they really need to fix (way too much time revising in AutoCad or Microstation).
Cheers, Win B.
