scheven_architect Posted February 20, 2011 Share Posted February 20, 2011 Hello, I was wondering which is the easiest way to scale an imported dwg file, or a group of objects in vectorworks. Free or by a certain value. greetings! Quote Link to comment
CipesDesign Posted February 20, 2011 Share Posted February 20, 2011 Most dwg files have their own scales, the scale used by the originator. The trick is choosing the correct "units" for the import. Once you determine what units were used for the dwg file (eg: feet & inches; feet; meters; etc.) if you use them to import then the drawing will already be to scale... Hope that makes sense. If you need to rescale an object or objects you can try the command "Modify/ Scale Objects". See help for more on the scale object command... Quote Link to comment
