scheven_architect Posted February 16, 2011 Share Posted February 16, 2011 (edited) Hello, Can someone explain me how setup model - level settings work? I saw a tutorial but i still don't understand. You have to set FF values, ceiling heights and floor thickness but the values of different floor levels aren't connected to eachother so if i change one the rest stays the same. If i for exemple wanted to change the height of one or all floor levels from 4 to 3 metres i would have to change all manual? greetings! Edited February 16, 2011 by scheven_architect Quote Link to comment
CipesDesign Posted February 16, 2011 Share Posted February 16, 2011 Yes, the Z values will need to be changed in the Layer Setup Dialog. One cool thing: you can do math in all the dialogs. Thus, instead of changing "4m" to "3m", you can simply add: "-1" and then hot tab (or return if you want to exit the dialog). Hope that helps. Quote Link to comment
scheven_architect Posted February 16, 2011 Author Share Posted February 16, 2011 TYvm! Quote Link to comment
