scheven_architect Posted February 14, 2011 Share Posted February 14, 2011 Hello, when i try to connect 2 different walls they are being connected but there is still a light grey line visible where they meet. any suggestions? greetings! Quote Link to comment
CipesDesign Posted February 14, 2011 Share Posted February 14, 2011 I notice this as well. Could you post a screen shot of it? My experience is that the gray lines, even though are annoying, don't seem to show up in prints. But maybe your case is different? PS: If you would create a signature which contains your OS and VW's versions it would be helpful... Quote Link to comment
scheven_architect Posted February 14, 2011 Author Share Posted February 14, 2011 Also, when i create walls on one design layer and then make a floorslab on another layer i can't see walls in 3d when floorslab is activated and vice versa, is this normal? and how could i see both at same time in 3d? Quote Link to comment
scheven_architect Posted February 14, 2011 Author Share Posted February 14, 2011 I can't upload an image, it doesn't work when i click on adding image Quote Link to comment
CipesDesign Posted February 14, 2011 Share Posted February 14, 2011 To upload an image Switch to Full Reply Screen, then click on File Manager. First Choose File, then Add File... Quote Link to comment
scheven_architect Posted February 14, 2011 Author Share Posted February 14, 2011 To upload an image Switch to Full Reply Screen, then click on File Manager. First Choose File, then Add File... Sorry it doesn't work, won't open anything. greetings! Quote Link to comment
scheven_architect Posted February 14, 2011 Author Share Posted February 14, 2011 Problem is now solved, don't know how i restarted VW. But I still can't manage to view all the layers of my model in 3d at once. greetings! Quote Link to comment
scheven_architect Posted February 14, 2011 Author Share Posted February 14, 2011 When i look at walls in 3d, i don't see other components in 3d. When i change for exemple from walls to floor slab view doesn't change at all. greetings! Quote Link to comment
CipesDesign Posted February 14, 2011 Share Posted February 14, 2011 Make sure Unified View is active. Quote Link to comment
