ionw Posted February 12, 2002 Share Posted February 12, 2002 Is there anyone who knows if this is possible? I use the Command- up-arrow or Down arrow to cycle the active layer, is there a way to do this for classes? One is, is it implimented already, if so what is the command, two is if notm is it possible for Nemetschek to assignthis functtionality to something like cmd-rgith and left arrows? thanks Ion Webster Quote Link to comment
BHowell Posted February 14, 2002 Share Posted February 14, 2002 I too would love to see this implemented or found, if it already exists. Thanks, Brooks Howell Quote Link to comment
ionw Posted February 15, 2002 Author Share Posted February 15, 2002 Hi Matthew, I was thinking as mundane a thing as cycling through the Alphabetical list found in the Class Modification Window. There Walls-Int comes after Walls-Ext-Frame and Window-main after that. Instead of the pop down where Wall comes before Window in the main list, and the types of windows and walls are deeper in the main category Wall or Window. I always thought that there weren't truly Sub categories, rather the hyphen was a key to VW to display then as such in the class pop downs in Obj info and in the Info Bar. My main use for this tool is to have method of checking objects for proper class association, for example choosing grey other classes, and then cycling through a layer and making sure that someone didn't draw something using the wrong class. Or more importantly in going through a civil drawing to set up a mapping. So for me anyway, I want it as a rapid way through all the classes, I don't care about the hierarchy. And like I said in my earlier post CMD-Left Arrow and CMD-Right Arrow would be perfect to cycle through an alphabetical list of Classes. thanks for your attention Ion Webster Quote Link to comment
Matthew Giampapa Posted February 16, 2002 Share Posted February 16, 2002 It is something we would like to do, but the problem is that classes are a tree like structure rather than a list. You can navigate up, down, in and out. If you can think of a good simple interface to display to the user for this, I would be happy to pass it along. Matthew GiampapaTechnical Support Quote Link to comment
TiTaNiuM sAMuRai Posted February 20, 2002 Share Posted February 20, 2002 If it is set up as a tree structure, a good example of key-based operation of such a list would be running IE5 under Windows 2000 (just an example). You can use the LEFT and RIGHT cursor keys to go in and out. Please don't make it like Finder's operation of directory trees (the designer of THAT should be shot... or shown the entire keyboard). Quote Link to comment
Sir_Dan_Fortesque Posted February 21, 2002 Share Posted February 21, 2002 Hello, You can browse through all used classes in your document with a VectorScript. It is very easy. Firstly used NumClass to determine the total amount of classes. Thereafter us something like this : strName := ClassList(intIndex); where strName contains the name stored at intIndex position within the Class tree. You can also get other properties of the classes. In the meantime Nemetschek will add it to VectorWorks, maybe this can help. If you need help coding this, tell me and I will help you. Friendly greetings, StarGateDesselBelgiumEurope Quote Link to comment
ionw Posted May 17, 2002 Author Share Posted May 17, 2002 I finally got around to doing something about this. What follows is the first working version. I made this a Command, assigned it to a command Key and now I hit that key and the arrows cycle me through the classes. It still needs work, because I don't know where I am in the list, but anyone can add that functionality. Procedure CycleClasses;VAR NextClass : STRING; X1,Y1,MouseX,MouseY : REAL; ObHd1: HANDLE; KCod,i : INTEGER; BEGIN i := 1; WHILE (KCod <>13) DO BEGIN { - until return is pressed - } IF MouseDown(MouseX,MouseY) THEN SysBeep; { -handles mouse downs- } IF KeyDown(KCod) THEN BEGIN CASE KCod OF 28: BEGIN { - '<-' key - } i := i - 1; IF i < 1 THEN i := ClassNum; END; 29: BEGIN { - '->' key - } i := i + 1; IF i = ClassNum + 1 THEN i := 1; END; END; { - CASE end - } END; NextClass := ClassList(i); NameClass(NextClass); ReDrawAll; MESSAGE ('Current Class is ', NextClass); END; { - WHILE end - } KCod:=0; DoMenuTextByName('Class Options',5);END;Run(CycleClasses); Thanks for the interest Ion Webster [ 05-17-2002: Message edited by: ionw@mac.com ] [ 05-17-2002: Message edited by: ionw@mac.com ] Quote Link to comment
