Guest Posted February 2, 2002 Share Posted February 2, 2002 Could you send a copy of this to me here? Suggestions for fixing: (1) Try using workgroup referencing to reference every layer into a new document, then remove the references and choose to keep the layers. Save, quit, restart. (2) Try saving as VW8 format, then open that up again after quitting and restarting. (3) Try exporting as VectorScript, then import the result into a new blank file after quitting and restarting. Quote Link to comment
roscolux Posted February 3, 2002 Author Share Posted February 3, 2002 My Stats- PowerBook G4/550 768mbRam. Anyway, I'm running VW 9.5 in os 9.2.2. VW 9.5 runs great, until about a week ago. Every time I open one file, when I switch to a different application, everything locks up and I must reboot. It does it right away, without fail, every time. Its just on this one file. This file did start out as a 9.0.1 file, and worked great with 9.5 for some time. All other files like this work great. I've tried switching workspaces, and everything, no help. I've reinstalled VW, I would reinstall the system, but it sounds more like a vw soft wear issue. Sounds to me like my file is corrupt. Any ideas on how to check/fix this file. Any quick ways to put all the layers into a new file, besides copying them and pasting them all, yada yada...? Any help would be great. ThanksDonald Quote Link to comment
TiTaNiuM sAMuRai Posted February 4, 2002 Share Posted February 4, 2002 I wouldn't recommend option 2 unless it's a last resort because re-translating from 8 to 9 has still a probability of introducing corruption itself. Quote Link to comment
