grant_PD
Batch rendering and saved views
-The batch render window seems unfinished. I cannot delete batch renders, because there is only a "start" and a "cancel." So I either lose all of my deleted batch renders (ie. they won't delete if you cancel out) or I have to start a render to delete one.
-When saving a batch render one cannot use the marquee tool to select the area that I want to render. I need to be able to use this.
-With both view, and batch renders, one should be able to update them, rather than re-saving them. I know it seems trivial, but in order to save them you must enter the name exactly or you get multiples.
1 answer to this question
I totally support the view/batch render issue !
There must be a way to connect between the two.
And also:
-to edit/update multiple batch render options.
-to create batch render from multiple views or cameras, with the same preferences.
